'01 V70 XC. So has anyone changed out this little beastie or is it a dealer only thing.
Modified by TWMn at 8:26 AM 5-12-2009
Re: Air temp. control sensor / ECC (TWMn)
Sure the fan spindle isn't just jammed up threads to prevent the fan from drawing air over the temp sensor wire? This is quite common (happened to both of my 01s). See "ECC has no heat" in the following link
http://www.freewebs.com/howard...s.htm
Do be careful taking out the ECC tho. Others have fried it taking it out. See "Electronic Climate Control Not Working" in the same link.
Not sure if the dealer can just replace the fan. I think a new ECC + install + software = $1000.
