Hello everyone, I'm new here, and it's my first post.<p>I just bought a used 2001 Cross country.<p>The problem I'm having is, when I turn the air on full blast, cold, it'll run for about 10-20 minutes with no problems. Then I notice the air in the car getting warmer and warmer. So I open the windows and keep it off for a little while then I turn the air back on to how I had it set and it'll work for for about the same amount of time.<p>What do you think could be the problem??
Re: Air Conditioning Problem 2001 Cross Country (BigBoy69)
as long as the freon level is correct, my initial guess is a bad compressor<br>i would have it checked for codes though...may also have set a pressure switch code
Re: Air Conditioning Problem 2001 Cross Country (lowbumpeR)
have set a pressure switch code<p><br>What is that?<br>
