It's finally gotten hot here again but I've noticed an issue.
When i run the AC for a while, maybe 1 hour, it stops blowing. Very specifically:
- The condenser still works, there's a trickle of VERY cold air coming from the vent.
- The blower still works, it whirs when you push it up to hi (or run it on auto) and it responds normally when you turn it down. When it's full blast the trickle of air coming out of the vents is higher than when its low, but it's GREATLY reduced from normal operation.
- Whether it's on Auto or a specific airflow setting it doesn't make a difference.
- If i turn it off for about 30 minutes, it works fine when I turn it back on.
Seems to me like there's some icing going on that's blocking the airflow.
Anybody have any experience with this?
