I have a pin-hole sized hole in the A/C radiator. They sell the recharge/leak sealing kits at the auto parts store, and I figure that it is probably meant for apps like this. My question: will this stuff gum up my system and lead to a total failure of the system? Am I better off getting the radiator fixed/replaced and how much will this cost?
Re: Air Con recharge/sealant (ecmiller)
Replace the condensor.
This junk, like stop leak for an engine will eventually KILL and gum up your entire system.
How new is your evaporator? If it's been a while, you can expect that to eventually start leaking as well. They ALL do. Nothing like watching that fresh 134a charge on a repair blow out another leak point. If your system is open to atmosphere at this point, that is not helping matters any.
If you've got a bad condensor and an elderly evaporator, you might as well bite the bullet and do them both (and the receiver dryer) all at the same time. Big dollars, but it will be done correctly.
The hole is from impact damage. (not from the inside) I must have hit some piece of debris, like a piece of gravel or a stick, it is in the front, low, where there is an opening below the bumper.
Is this repairable? Or do I need to replace the radiator?
It doesn't matter whether the hole is from the outside or the inside. A hole is a hole and a leak just the same. It's best to replace the condenser under those circumstances. I don't recommend repairing automotive condensers.
And again, it's called a condenser (or sometimes a condensor), not a radiator. And it's not to be confused with the condensors (or condensers) found in point style ignitions.
When the radiator leaks, your car overheats.
When the AC condenser leaks, you overheat.
I'd also take a long look at the evaporator before investing large dollars in the AC system.
