1 - 9 of 9 Posts
I've seen some posts about aftermarket products (specifically the chip and exhaust) but haven't seen anything about the warranty. Do any of the aftermarket products void the warranty? I can't image the exhaust would, but the chip???
thanks,
Two problems with that. First, you'd need to keep a second ECU (that's expensive). Second, the dealer can most likely read the fault codes and know that you were running higher boost.
Still, you may want to check out SEMA's website for more info, but I believe the burden of proof that a mod caused the damage lies with the dealer.
Warranty vs aftermarket
Rescuing an old post from, like, 2001. What's the new story on this subject. I'm a new T5 owner interested in increasing my cars performance and the warranty issue is very important to me. Bottom line is how much can I do to increase performance and still not disturb warranty concerns.
Exhaust, intake, suspension, ECU? What and how?
Re: Warranty vs aftermarket (tobinsmith)
Frank Derks from Eurosport in Canada was pretty confidant that replacing the ECU, exhaust enhancements, K&N intake kits etc., would not cause any issue with the factory warranty.
I was told this one time by someone else who was in the legal field, he was positive that you had to prove the modification caused the problem/failure if it ever happened.
Tobin - I'm in Frederick, know the Olney area well. Have you modified anything on your T5 yet?
Sam
My service manager told me today that it would be pretty hard to impossible for a dealer to know that you have a modded ECU installed in your car.
Now, if you also have a pipe and an exhaust, that could be a little telling
JRL
1 - 9 of 9 Posts
