1 - 20 of 38 Posts
Well, the 850R deal fell through, and the owner of the lot never called me back. But, I am ordering new bilstein shocks and struts, which i hope will make a difference in he ride of the car, which is horrible as of right now. I talked to a vovlo mechanic about the ECU upgrade, and disappointingly, he told me that the 850 was never meant to be a "performance car." Although this may be true, I have been looking into some of the aftermarket turbo kits out there. Any suggestions as to a good turbo company, or if it's worth my time?? Thanks
Your Volvo Mechanic is an idiot. What year was it that the 850 won some major races on the European circuit? I forget, but what we drive on the street is a torqued down version of what Volvo used with it's professional racing team. With the right mods and saftey precautions, the 850 can be a very challenging rival to many race cars out there. A good turbo company you ask? Hmmm, actually more people are into the things you're thinking of over on the <A HREF="http://www.volvospeed.com" TARGET="_blank">http://www.volvospeed.com</A> message board than here. I suggest you go brouse over there and see what's availabe. If you want a bigger turbo, go look in the for sale section. You will need to re-map your ECU and do some good basic ground-work maitenance before attempting these things so you don't BLOW YOUR CAR UP, but modding your car is well worth it, if that's what you want.
Also, the proper modifications to your 850 can make it a really fun car to drive. You've gotten off on the right track w/ suspension upgrades. Don't forget brakes to slow you down!
are you looking for a turbo kit to bolt up directly or any custom job?
Re: Aftermarket turbos for 850? (Swede115)
Carefull with the Bilstein HD's (if that is indeed what you have purchased!)<p>They are noted for a VERY firm ride, some say "harsh" With any new struts & shocks, replace the spring seats (use Volvo parts, or Sachs), and I highly recommend replacing the shock mounts as well.<p>ECU upgrades are great in 850's. Significant performance upgrade <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: (MadeInJapan)
Thanks so much for the advice, but, where is the for sale section you were talking about?
Re: Aftermarket turbos for 850? (RussBert)
really? well, thats definitely something i will consider. do you have any suggestions for a substitute for the bilsteins that would still be of good quality but maybe of a bit less firmness?
For sale section of VS: <A HREF="http://volvospeed.com/vs_forum/For-Sale-f9.html" TARGET="_blank">http://volvospeed.com/vs_forum/For-Sale-f9.html</A>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Swede115</b> »</i></TD></TR><TR><TD CLASS="quote">Well, the 850R deal fell through, and the owner of the lot never called me back. But, I am ordering new bilstein shocks and struts, which i hope will make a difference in he ride of the car, which is horrible as of right now. I talked to a vovlo mechanic about the ECU upgrade, and disappointingly, he told me that the 850 was never meant to be a "performance car." Although this may be true, I have been looking into some of the aftermarket turbo kits out there. Any suggestions as to a good turbo company, or if it's worth my time?? Thanks</TD></TR></TABLE><p><br>What car are you currently driving?
I am selling a stock S60 V70 R Turbo that would bolt right up with the right flange. Let me know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Swede115</b> »</i></TD></TR><TR><TD CLASS="quote">Hmmm, do you have any pictures? Im very interested.</TD></TR></TABLE><br>It's big, round, looks like a snail <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
TD04 15G - 850 Turbos<br>TD04 16T - S70 T5<br>TD04 18T - S60R<p>Those are all bolt-on for the HPT models. The 16T will work on the 850 Turbo without any modifications. The 18T will also bolt-on, but will require a new program (re-flash), also larger injectors are recommended. <p>BTW, is your car N/A? If so, I would not recommend a turbo install. It's a waste of money. You'd end up spending more money than just selling your car and buying an 850 Turbo. Since everything is bolt-on, start with the 850 Turbo as a base. It doesn't make sense to upgrade an N/A 850 when there are turbo models out there.<p>If you do have an 850 Turbo already, then I would suggest the 18T. It's good for 350hp at the crank max. The 16T is only good for an extra 10-15 HP more than the 15G at most. The 16T isn't worth it, unless you've blown your stock turbo and are looking for a cheaper replacement. It probably spools a bit better too. If you're looking for something more serious, there are quite a few people out there running the GT28RS. That is not bolt-on and will require modifications or replacement of the downpipe and manifolds. There are some premapped software out there for this turbo.<p>Bry<br>
Discussion Starter · #16 ·
Re: (TRQSTEER)
I not going to lie, im pretty new to this whole thing, and im not exactly sure what you mean by N/A. Do you mean that the v70R turbo would not bolt on to my 850 glt?
Yo Swede115, maybe it's about time you mention what particular car you're wanting to install this turbo on?!
N/A is normally aspirated, meaning NO TURBOCHARGER!<p>Unless you 850 GLT is a '97 with the low-pressure turbo, you aren't going to install a turbo on your car, unless you have,<p>lot's of money,<br>much automotive experience<br>...and lot's more money!
His GLT is a '96.... (from his signature)<br>Then this 850 is indeed an N/A (non-turbo), and his mechanic was correct to begin with when he made the right statement that his car was never meant to be a "performance car." Now, I will also agree with the other poster: If you want a faster car, sell your N/A and buy one with a turbo.
Discussion Starter · #20 ·
Re: (MadeInJapan)
I understand what you're saying, and it would make perfect sense to buy a turbo, but just out of curiosity, how much money would it cost me to install a turbo properly? I probobly wouldnt after all the advice, but im just wondering. How about an ecu upgrade? Would anyone recommend this?<br> By the way, the car is a 1996 Volvo 850 GLT, and it is as slow as hell, and i do realize that it wasnt built to be fast, like the R, but the car runs perfectly, in fact, a lot better than any new cars ive driven, and i would hate to let it go for a turbo that could be a lemon. At the same time, I would like to make it a bit faster.
1 - 20 of 38 Posts
