Glad to see some sane discussion here, FWIW I dropped out when the "middle school girls" took over.
@Stephen.G.Fiddes - It seems like you have a handle on most of the concepts, but I'll try to refine a bit.
PWM (which is Pulse Width Modulation, btw) does have almost everything to do with WMM failure, specifically because it produces large voltage spikes, or transients, on the power rails each time the ballast tries to restart the bulb. I do agree that this problem is aggravated by cheap ballasts that have a minimal power filter.
EMI does not kill microchips, to the contrary, electronic devices are built to tolerate EMI (per FCC regulations) and not produce it when operated within their design specification. Voltage - specifically, either in excess of the breakdown voltage of the body diodes within the integrated circuit or sufficiently negative to forward bias them (typically, -0.7v without additional design consideration) - is what causes the failure. The large voltage spikes basically burn through the silicon oxide insulating substrate the the transistors inside the chip are sitting on, shorting them out.
This sort of voltage isn't likely wirelessly transmitted from the HV lines in the ballasts. Direct inductive coupling is nearly impossible - the bulb wires are < 1' long and don't run parallel to other wires for a significant distance, and the current is low. For RF coupling, the supply impedance (or internal resistance of the car battery) is very low, which makes any power wire a poor receiving antenna. Even the data wires are 120ohm terminated (for exactly this reason) preventing standing waves from forming. Only the direct discharge of a large inductor (the ignition choke) into the power system is capable of producing a WMM killing transient.
As a counterexample: The ignition system fires at a much higher voltage (30kV vs 4kV) and current (A vs mA) thousands of times persecond minute. This does not produce voltage transients on the electrical system - although it does produce significant EMI that the rest of the car is designed to deal with.
That said, your conclusion:
FYI, moving a ground point changes things because the ground system is not a perfect conductor. Each foot of wire, each splice, and each connector add measurable resistance which affects the voltage differentials produced by a given current. This is why high-powered amplifiers use bigger wires than, say, turn signals. Typically, we consider the chassis to be a nearly ideal conductor, but the WMM does not ground directly to the chassis. It happens to splice into a ground that is shared with the headlights, which allows spikes relative to the supply rail.
The fog modification is much simpler, actually, if you don't mind running a few wires. I personally think that it's more reliable in the long term since eventually capacitors will lose electrolyte. My problem is that it requires the fogs on all the time, which *does* waste power since they produce virtually no useful light. Worse, having them permanently wired to the headlights defeats the entire purpose: the correct use of fogs is to allow driving at low speed in deep fog with the headlights off to reduce glare
Is correct, your protection will be in the relay harness which has a separate ground point.- If I were to run the OEM Headlight power, down to the fog lights, the CEM would see the fog light bulbs and that will avoid the BOW (may have to convert to 55w fogs)
- I can then use that same wire going down to the fog light bulbs, to trigger the relay on the HID Harness, which will have the ballasts drawing power directly from the battery, and grounded to the chassis.
This wiring configuration will have my headlight switch working exactly as it should, fog light wires stay disconnected, and the fog lights turn on with the headlights. It SHOULD also prevent blowing up a WMM.
Sorry if you think I have tunnel vision - it's not. Besides my background in EE, I've been a ham since 98 (KG4AUW) and am an Extra. Without education, I can see how both sides can seem reasonable, at which point it becomes a popularity contest. But as far as scientific method, experimentation, and documentation go, there is just nothing to support that shielding the HV wires does any good. I'd be glad to be proven wrong - always open to learning something.I think you missed my point that I took out of this thread on the WMM failure... I'll be disabling the PWM prior to doing anything (or at least it will be circumvented by wiring through the relay harness discussed later). But from what blaze was saying (ok, halfway saying without telling his full solution), It has nothing to do with backfeed through the wiring, rather electromagnetic (AKA, radio wave style) interference. This makes sense because it's known that it's a microchip that goes out on the WMM, and EMI can easily fry a microchip if it hits it at the right resonant frequency. Therefore a diode wouldn't do anything if that's the case, nor would the PWM Have any affect on it. Rather, poor quality ballasts and bad shielding to prevent this EMI from escaping the wiring between the ballast and the bulb socket, and getting into other electronics that may not be properly shielded (WMM). So adding extra proper shielding SHOULD in theory prevent this. (Note: I understand that the PWM is still an issue for the ballasts, but I think people have honed in so bloody far on the PWM, they're looking with tunnel vision vs big picture) (note2: I could be off base on that observation of what I read out of the thread, and may be able to do more testing after I get my car tomorrow, but to me with my little bit or electrical and ham radio knowledge it makes sense. Especially considering that people have killed the wiper motor with all other given circumstances that have been tried.
Actually, unlike a resistor harness, the KBOWE that I designed produces (virtually) no heat. It averages out the PWM waveform and produces a slightly lower voltage. The only loss is the ESR of the capacitors, which being large electrolytic types, is quite low (a few mOhms max, much lower than the headlight connectors themselves).Wiring: I don't want a BOWE because that spells Heat and wasted electricity to me It's not that complex of wiring to get to the fogs. I'll be running 2 pairs of wires (one from each headlight socket, down to the fog light), with a (+) branch coming off of one of the pairs to trigger the relay... No permanent modification to the vehicle.
