The aftermarket adapter harness has a blue wire on the green connector that's labelled Power Antenna. The instructions call it the Power Antenna/Remote. Do I need to connect this to the Remote wire coming from the Head Unit?
I was under the impression that the remote wire enable was established from the head unit. Is this correct? Or is the remote wire enable coming from the car connector?
Discussion Starter · #2 ·
Well, I'm just going to go with my gut and not connect the wire.
Its probably not much help since I've never installed an aftermarket HU in a P2 car, but based on other installs the remote wire is either to turn on the head unit when the car turns on, or for an external amp to turn on with the car. If the HU turns on with the car without the wire connected, its for an amp, if it doesn't turn on or is always on, you'll need to connect the wire.
