1 - 1 of 1 Posts
Hi...I just installed a water temperature, oil pressure, and transmission temperature gauges in my daughters 1995 - 960. I know the stock coolant temperature sensor is located at the rear of the cylinder head and is a bear to get at . What I need to know are the best places (read easiest) to install the sensors for the gauges I installed? I'd like to keep the stock gauges, so just removing the stock sensor and installing the sensors for the aftermarket gauges is not an option. Any advice or suggestions will be much appreciated!
Modified by nlemerise at 8:24 AM 4-6-2009
1 - 1 of 1 Posts
