1 - 11 of 11 Posts
I am looking to install an aftermarket head unit (Pioneer avic-z1 or Alpine, or ...) but was told by a volvo dealer service tech that when the head unit is removed that certain functions would be at risk of failure, such as abs, air bags etc. I dont know if this is scare tactics or what but i want to get to the bottom of this. Any thoughts out there?
Re: aftermarket audio (campwc)
Im not an expert but I believe that tech doesn't know what the hell he's talking about. Although an error may pop up (I believe some people have had error codes show for the airbag when they've installed their iPod adapter to the stock radio) its easily fixed by the dealer and everything will still be 100% operational. The airbag in the least would not rely on the stock head-unit in any way IMO.<p>There are several guys on here as well that have completely overhauled their audio system and they run perfectly with no airbag (or other) problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>campwc</b> »</i></TD></TR><TR><TD CLASS="quote">I am looking to install an aftermarket head unit (Pioneer avic-z1 or Alpine, or ...) but was told by a volvo dealer service tech that when the head unit is removed that certain functions would be at risk of failure, such as abs, air bags etc. I dont know if this is scare tactics or what but i want to get to the bottom of this. Any thoughts out there?</TD></TR></TABLE><p>Well, I have to say I am no longer surprised at what comes out of a Volvo Tech's mouth. <p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0">
Re: aftermarket audio (needsdecaf)
No failures, but you MAY get some lights, especially the SRS light and you will have to go to the dealer for a reset
The tech is correct in the fact that there is RISK involved.....<p>There is an ecxellent write up in the audio section that explains how to avoid this.
Re: aftermarket audio (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">No failures, but you MAY get some lights, especially the SRS light and you will have to go to the dealer for a reset</TD></TR></TABLE><p>Disconnect the battery and wait 15 minutes before removing the head unit and you can avoid this one
Re: aftermarket audio (frankhoffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>frankhoffy</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Disconnect the battery and wait 15 minutes before removing the head unit and you can avoid this one</TD></TR></TABLE><p>I think Frank might have some experience in this! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Disconnect the battery before starting the work and do not turn the car back on without the head unit connected. Buy the Accessory electronics module from Volvo. It'll give you a bunch of connections you won't find without it. Speed signal for nav, accessory, etc. <p>You can also buy a dash installation kit for DIN and 2-DIN heads from Volvo. <p>Finally, If your dealer's parts department sucks, like mine does, call Trevor at Boston Volvo.
Re: (Andy Wehmeyer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Andy Wehmeyer</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Finally, If your dealer's parts department sucks, like mine does, call Trevor at Boston Volvo.</TD></TR></TABLE><p>wait a minute.... your dealer has parts dept? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0"> I wish mine did.
Don't know why all these Volvo shops are so afraid of aftermarket audio... Everything wired up pretty much the same as any other car... You'll lose steering wheel mounted controls... Most of the SRS lights occur because of climate control module being removed without the battery being disconnected. You're always supposed to disconnect battery when doing audio or electrical work on the vehicle Volvo, Honda, Ford, ALWAYS.
1 - 11 of 11 Posts
