1 - 20 of 27 Posts
hi,<p>is there anyone has installed a after market HID and got no problem at all (no bulb out msg, no wiper motor fried) ?<p>really keen to try HID but problems mentioned before has really scared me off.<p>any reliable brand to recommend?<p>thanks a lot <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Re: After market HID (andrewlim)
Mine haven't had any real issues, and it is the 55w kit from SharpHID. It isn't really the kit, each car seems different so it depends on how your car reacts to it...
I have the 55W kit from SharpHID as well, and it would only work with the Bulb Out Warning canceler. The lights would also flicker if I start the car with the lights in the off (DRL) position, as opposed to the on position.<p>As AJ said, it seems that each car is different with what works.
carreragt7 and LennyQ,<p>thanks for your fast reply !<p>as i am from Asia, my S40 didn't come with DRL, so i really don't know the after effect of installing Sharphid, as most of you here come with DRL, right?<p>anyway, thanks a lot !
I got the 35W kit with 6000k bulbs. Been working fine and no problems since day 1. I think it's pure luck if they work or ruin your car.
Re: (Vash13)
Vash13,<p>is good to know that you are one of the lucky guy. are you using SharpHid as well? do you use Bulb out canceller as well?<p>thanks <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <BR><BR>
<i>Modified by andrewlim at 12:24 AM 7-2-2009</i>
Re: (Vash13)
andrew where are u based?><p>i have had mixed luck with HID kit. basicaly our cars are very sensitive, so my installer had ot run through a few different kits before he found one that worked..<p>it worked fine for a while but after a while it developed problems e.g. only one light would come on, i would have to slop restart the car etc for both to come on.<p>in the end it was just too much hassle, so went back to stock.
Re: (Mistral)
Had a HID kit with 6000k bulbs and BOW cancellers and the wiper motor fired the same day I installed them.
I haven't had the wiper motors fried yet, but only had my 55w kit for like few months. Had the 35w kit for about 2 years without wiper motors problem. One of the ballast blew though (prob my fault for leaving lights in on position when I switch on the engine). I have the battery harness but this means there is the "low beam failure" message, as the harness draws very little current, signs of a damaged bulb.
Re: (lando_pr)
lando pr,<p>thanks for your info ! mind to tell which brand fried your wiper motor?<p>so are you still using HID now? or gave up ?
Discussion Starter · #13 ·
Re: (fone)
fone,<p>thanks for your info too ! <p>i believed installing after mkt HID in our S40 is all depend on your luck. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
i bought an aftermarket, no name brand HID kit for $75 3 days after i got my S40. I don't know what wattage they are but there 8000k's. Ive had no problems with them or messages at all. for $75 i want expecting great quality but they are comparable to previous kits ive had.
Re: (andrewlim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>andrewlim</b> »</i></TD></TR><TR><TD CLASS="quote">fone,<p>thanks for your info too ! <p>i believed installing after mkt HID in our S40 is all depend on your luck. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> </TD></TR></TABLE><p>I'll be in Singapore until 14 July (tentative), if your need help (and if you are nearby, ie Johor), I can help with installation if you want to drive down.
Re: (andrewlim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>andrewlim</b> »</i></TD></TR><TR><TD CLASS="quote">lando pr,<p>thanks for your info ! mind to tell which brand fried your wiper motor?<p>so are you still using HID now? or gave up ? </TD></TR></TABLE><p>This is the ballast the kit I bought used:<p><IMG SRC="http://www.sagahid.com/tienda/images/uploads/Ballast_Inside.jpg" BORDER="0"><p>I went back to halogens.
Discussion Starter · #18 ·
Re: (fone)
fone,<p>thansk for your offer !<p>but i think i can't make it.<p>anyway thanks a lot <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: (lando_pr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>lando_pr</b> »</i></TD></TR><TR><TD CLASS="quote">Had a HID kit with 6000k bulbs and BOW cancellers and the wiper motor fired the same day I installed them.</TD></TR></TABLE><p><br>Boricua! did you get the bow cancellers from SharpHID? The same thing happened to me when i bought some generic ones, but thank god the ones from sharpHID have been sucessful installs in two S40s<br>
Re: (heico2.4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>heico2.4i</b> »</i></TD></TR><TR><TD CLASS="quote"><p><br>Boricua! did you get the bow cancellers from SharpHID? The same thing happened to me when i bought some generic ones, but thank god the ones from sharpHID have been sucessful installs in two S40s<br></TD></TR></TABLE><p>Hey, saludos. I got the HIDs from a local supplier in Carolina. Got the kit including BOW cancellers. Are you sure SharpHID has been sucessful in S40s that have had problems with the wiper motors before? The warranty for my car is about to expire and I'd rather stay with halogens than to pay $400 for a wiper motor. How long you've had your sharphid kit for? Did you get the 35w kit with the BOW cancellers? <p>
1 - 20 of 27 Posts
