1 - 9 of 9 Posts
I broke the engine with totally new internals and now its working fine .i had some problems regarding turbo all is fixed car performance is much better than it was before , it has elevate software elevate dp and exaughst.
I have a problem coolant water after i go for a trip like 40 km goes down and i get a warning in red regarding coolant , i check radiator hoses and im 100% sure there is no leaks as all the hoses and clams all are new , new thermostate assembly and new water bump .
I belive its a problem with my cylinder head , cause yesterday i see oil level is higher than normal which indicates water gets to OIL!!!,!,!,!, Now i am deassembling the cyl head , should i change the cyl head to new one or , give to workshop to fix cylinder head . If i fix my cyl head with workshop , will that affect the car performance as my mechanic said ??
Compression test is done and car performs perfectly , car delivers more than 350 HP but problem now there water with oil , and sometimes in low RPM aroun 800 i get flashes of red oil mark in dash board flashes when rom goes higher it goes.
my guesses are 1) head gasket, or 2) cracked sleeve, neither are good news for you
Is your oil a milky color?
My guess is that if you had all that stuff taken apart, the head gasket is most likely. I don't know what happened that you had to rebuild the engine though. Did your machinist do anything to the cylinders? He might have been too aggressive with re-honing the sleeves, and that could have caused a failure there. If not, the head gasket probably didn't seat properly & you're leaking there.
Actually , i did the rebuild because of coolant leak that leaded to exccessive heat before . I changed all the internals and fixed two cylinder sleves and installed new pistons, con rods, big end bearings , main bearings , water bump, thermostate assembly , new cam shaft seas , ew cranck shaft seals front and rare + used cylinder head
But for the setup i bought a used cylinder head , even gasket where new genuine .
Even if there crack in sleves i will get white smoke but there is no white smoke , car perform strongly , holds 19 psi of boost with no probem.
Problem is noticed after taking the cyl head off , cylinder block and sleves are okay problem from cylinder head in cylinder number 5 , today workshop is working on this head tonorrow it will be inspected to get sure 100% no leak before we install it back .
1 - 9 of 9 Posts
