1 - 20 of 25 Posts
Hi all
New to forum so please forgive me if this is posted in wrong place
My steering has developed a weird fault/feeling
Car is a facelift C30 D4 61 PLATE/94K ish miles
The power steering works .. lock to lock is smooth .. but between 11 and 1 o clock on the wheel it just feels stiffer than usual ? So all the lil inputs you put in to the wheel to make the car stay straight because they take more effort now are much more exaggerated making the car feel weird and unstable .. Much more noticable at 60/70
Had the car 2 month .. its had a new battery and a new alternator (yesterday as garage said it was over charging) and was kind of hoping the issue was a symptom of the alternator .. turns out it isnt .. garage also changed fluid out as they said it was manky which i can believe at that mileage
Pump whines but its electronic so it always will ?
Im fairly hands on but dont really want to start replaceing parts for the sake of it without proper diagnosis
Any help much appreciated
Paul
Hi all
Paul
Welcome aboard.
As for the whine, you more than likely have some air bubbles in the fluid. You could try swapping in some fresh new fluid and then manually bleed the system. My pump was whisper quiet until I hit what must have been the granddaddy of all raccoons, and then the whining started. Removed as much fluid from the reservoir as possible and then bleed the system. No more whine.
119984
Raccoon....pump is just behind here.
Thanks for the reply
Garage have already done the fluid by means of sucking it out and refilling and then again after a run round the block
I can live with the whine .. its more the twitchy steering .. the car just feels heavy and sluggish
When you say twitchy I’m trying understand what is going on exactly....
With any luck it may work itself out...the whine.
Its more noticeable at 70 .. between 11 and 1 o clock steering it feels stiff .. so all the tiny lil inputs and adjustments you put in to keep the car in lane and going straight take more effort .. which makes them bigger movements because its harder to turn .. its hard to explain but could be noticed straight away
How long ago was it aligned?
Another thought is, I believe these cars have speed sensitive steering which will make the steering wheel feel firmer at speed and easier at low speeds....Someone else may chyme in on that ahead of me as I am looking into it just the now.
I believe this to be true aswell
But i have no idea how to test this ? Steering could be stuck in slightly heavier mode ?
From what I’ve just read, they do in fact have it. Apparently at higher speeds the steering becomes firmer to aid in high speed control. (More effort to turn the wheel). Now, if it is doing this at lower speed, than another issue could be at play. But you said, 60-70......mph or kph?
Sorry
70 mph
What regulates this ? Is it the pump or a relay or ?!
Sorry
70 mph
Looking into that just the now..lol. What year is your car?
Its a 61 plate
D4 5cylinder diesel
Well, if it is harder at speed then that would mean that it is working correctly. It’s easy when parking, correct?
I also had to look up the UK plate system as 61 didn’t mean much to me. Lol. 2011-12 correct?
Discussion Starter · #16 ·
Yes 2011 .. i didnt realise you werent from uk lol
What your saying is right .. but .. its heavier than when i bought it 2 month ago .. like it doesnt self centre properly and takes more effort to move
Its really hard to describe ..
Tire pressures on point?
Yeah .. First thing I checked when it started to feel weird .. 36 psi all round .. although .. the fronts are probably have 30% wear left on them ?
What is the max cold pressure of the tire?
1 - 20 of 25 Posts
