1 - 17 of 17 Posts
hey guys, me agian with my crazy Q's. i posted a question on one of the old post about adjusting the level of the headlights (non xenon), however no response. So just a quik question. how do you adjust the level of the lights on a 2008 non xenon s40?
Re: adjustbale headlights (gonefly)
Never had to adjust a set yet on a 08. Hopefully someone else can chime in otherwise i can check on VIDA on monday.
I think there should be two knobs over the top of the headlight assemblies if you pop the hood. Have you checked the owners manual on how to? I think there is a page for that...if I recall correctly.
Use the search engine here, I'm sure you will find it there...with pics and everything.<br>
Check out the stickied "How To" thread at the top of our forum and see if the pics and screw locations match your vehicle. I tried to raise my OEM HID's with no luck. The cheezy plastic screws just click, click, click and do nothing. I even removed the lamp housings to get direct access to the adjustment, still no luck in adjusting them higher.
Re: adjustbale headlights (AlaskanAWD)
The other post tell nothing of the 2008 headlights. <p>As you may notice i have an unanswered post there too. I took off my headlights examined them and could not find anything that would adjust the headlights. however there are many screws inside the projector itself. One of those may be it. <p>Nothing in the owners manual either.
On the outside of the 08 head light there should be 2 spots to fix a hex key into.<br>These are your adjustment nobs.<p> <IMG SRC="http://www.trademotion.com/schematics/9/9726022.gif" BORDER="0"> <br>from MySwedishparts.com<p>parts - 18) Adjust screw Back
is this the same for an 05? Mine might as well be pointed backwards. They only illuminate the first 15 feet in front of the car and need to be raised.
Re: (Jeremy Nathan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Jeremy Nathan</b> »</i></TD></TR><TR><TD CLASS="quote">is this the same for an 05? Mine might as well be pointed backwards. They only illuminate the first 15 feet in front of the car and need to be raised.</TD></TR></TABLE><p>You sure that's not just the crappy bulbs used? I am thinking of changing the low beams out with some Osram nightbreakers.
Re: (Veefifty T5AWD)
tried it out and nothing. it feels like something cracks and it does spin but the headlight level does not move an inch.
Discussion Starter · #14 ·
Re: (Vash13)
im adjusting #18 on the diagram above. ill take some pics too. <p>i tried spinning the hex screw to the left and right with no vertical movement of the light.
Re: (Jeremy Nathan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Jeremy Nathan</b> »</i></TD></TR><TR><TD CLASS="quote">is this the same for an 05? Mine might as well be pointed backwards. They only illuminate the first 15 feet in front of the car and need to be raised.</TD></TR></TABLE><p>Mine are the same way. I have the auto levelling xenon lights and they point straight down. Replaced a $300 level sensor that did nothing. Can't get them to come up manually either.
Discussion Starter · #17 ·
Re: (Vash13)
the one just below the round #15. think it could be the other 18?<BR><BR>
<i>Modified by gonefly at 4:19 PM 8-21-2009</i>
1 - 17 of 17 Posts
