So I lowered my C30 with set of H&R springs with Bilstein shocks. I took the car in for an alignment and was notified that the car has fixed upper rear camber links. Should have have read up and payed attention when I put the suspension in.
Any how, there are a TON of adjustable rear camber links for the C30 as it uses the same links as the Focus, and Mazda 3. I have seen everything from $120 for a set of 4 rear adjustable links on eBay, to a pair of links costing $300. Sad thing is a lot of these cheaper links look exactly the same as the more expensive ones. I am sure the are using different bushings?
So my question is to those that have purchased adjustable rear links. What did you use? Cheap eBay? Or top of the line ? Or is there a nice middle road?
