I am about to install my SPC adjustable rear upper control arms. I would like to get the camber close to where I want it, so that the alignment shop is not too challenged.
Does anyone know the correlation of arm center to center length change and change in camber angle?
2009 C70
Thanks.
It depends entirely upon your ride height. Stock springs, lowering springs, coilovers, etc.
What is your camber currently at? I would set the camber arms just a tad longer to make the camber a little less aggressive. Adjustment is easy on the SPC arms, so any alignment shop won't have much difficulty dialing in what you want.
Installation of the arm on the passenger side (with the gas cap) will be a little more challenging to access the upper bolt. But it's still DIYable. I would suggest starting on the driver's side before you're completely discouraged by it though!
Good luck! I should probably upload the how-to video on this.
