Dear all,
in XC60 (2019, inscription) I hear a click- and rattle-noise when using Adaptive cruise control during slowing down. Click noise appears at all speeds, while rattle at very low speed and/or stoping. It is very annoying, as this is clearly heard all the time when using the adaptive cruise control in the traffic.
Anyone experience this?
Anyone solved this issue?
Is there anyone not having this noise under such circumsences?
I would appreciate some comments.
You're in the 2010-2017 P3 section. You'll waant to post this in the SPA section.
To stop the car without your intervention two parts of the braking system are used: the active brake booster and the ABS (anti-lock brake system) pump. The click is the brake pedal being moved down by the activation of the brake booster and the rattle is the brake pump. I assume that you have no radio or other sounds in the car when you hear this.
