1 - 2 of 2 Posts
Accessory Belt Tensioner Pulley Specs Needed
I ordered a new pulley for the serp belt tensioner when I changed my A/C compressor. It was just a little too wide so it would hit the engine block if I let it take the slack out of the belt. Obviously I took it right back off, but now I need one that will work.
I had purchased this one originally: GOODYEAR Part # 49024 A/C Drive Belt Idler Pulley; Belt Type: 6 rib Poly-V, Smooth; Non-Flanged; Thermoplastic; Pully Width: 26.1mm; Bearing ID: 17mm; Bearing OD: 70mm
Category: Idler Pulley
My thinner options are:
DAYCO Part # 89133 {#89133FN} Drive Belt Idler Pulley; 70mm x 17mm Flat Steel, 24mm wide
Tensioner Pulley
OR
GOODYEAR Part # 49161 A/C Drive Belt Idler Pulley; Belt Type: 5 rib Poly-V, Smooth; Non-Flanged; Thermoplastic; Pully Width: 24mm; Bearing ID: 17mm; Bearing OD: 70mm
Poly-V; Tensioner Pulley; Smooth Pulley
* Stocked in outlying warehouse--shipping delayed up to 2 business days
If anyone knows the width of a stock one or could easily measure and get back to me that would be great!
Thank you for your help in advance
1 - 2 of 2 Posts
