1 - 2 of 2 Posts
Hi,
2006 C70, Looking to do a drain and fill on the transmission when the weather warms up a bit more wanted to check the oil level today but the dipstick cant be removed because there are cables over it and in the way ? The top cable that says made in Spain is easy just a screw, I'm referring to the bracket below it thats right above the dipstick. How exactly are those cables above the dipstick removed out of the way ? there seems to be some sort of bracket ? Sorry if it's a silly question. Any help appreciated. Thanks
I was able to get the dipstick out without removing anything by accessing from underneath the car. There's a tab you have to pry while pulling out the dipstick. Takes a bit of work with one hand but doable. Why do you want to drain and fill? I'd be careful. If the Transmission is on it's way out you may accelerate the process. I did on my 850.
1 - 2 of 2 Posts
