1 - 9 of 9 Posts
Anyone having aceleration problems when merging into traffic or WOT when power is needed most?
My T5 (upgraded with POLESTAR) has had a inconsistent lagging problem from the start. I had Polestar upgrade installed hoping it would solve the problem, with no results.
Have you had it into a dealership? You are going to have to hook it up to VIDA to see if any codes are thrown.
To answer your question, no.
Sent from my iPhone4S using Tapatalk while on the toilet.
If you have an automatic then I can relate. It is your transmission. To test the theory switch it over to psudeo manual and try it out. If yours is like mine there will be no lag. I have the Elevate mapping.
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
I have found with the elevate upper inlet manifold a lot of this problem is reduced on the auto car, it tailors the car more
Towards the mid-upper RPMs. Instead of the mid-low torque monster that it is. I love it on the Hwy
I installed the lower manifold and it is amazing the difference it makes. The car litterally will snap your head back with 1/4" of throttle it is so responsive. Auto trans is still crappy but it Definatly makes the best of it.
1 - 9 of 9 Posts
