Hello everybody
So i did some pulls from 80-120km/h(50-75mph) and noticed some big difference in when the AWD is on and disengaged(pulling the handbrake 1 click)
80-120km/h 3rd gear with AWD 4.95s
80-120km/h 3rd gear without AWD 3.92s
Is the AWD torque limited? or does the AWD really pulls this much HP away?
'05 V50 T5 AWD manual
the 0-100km/h(0-60mph) i did in 7.1s, so that about correct according to oem spec
This was all done without and without DSTC and tractioncontrol/ESP completely shut off
The AWD should not be engaging at that speed. There is no wheel speed difference for the internal Haldex mechanical pump to work and the electric boost pump would not last if it tried to maintain pressure all the time.
(I am not sure if the Volvo Haldex uses an internal mechanical pump in its design.)
Very strange results!
2007 Volvo V50 T5 AWD M66
Shouldn't make a difference as the AWD only comes on with slip and the drive shaft skins all the time with the pump in the rear differential.
Do you mean with DSTC button off or drJonez denanny mod? As I think that in the second case handbrake trick is not working, atleast on mine. On DSTC deactivated indeed I can disable AWD by handbrake trick, but it seem to not work when de-nanny mod is active...
