The ABS warning light on my '94 850 is lit. When I run a diagnostic on the module it reas 4-2-2, Rear wheel circuit return valve: open circuit or short circu. How do I fix it?
Re: ABS Warning Light (gir)
There is a big black relay clipped by the ABS ECU under the hood. That relay supplies power to the ECU and is more than likely the culprit.<br>I would start there.<br>Also check the connector on the L/F strut tower for corrosion <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Why bother, it's your module.<br>That's what it always says but it's the module
Re: ABS Warning Light (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">Why bother, it's your module.<br>That's what it always says but it's the module</TD></TR></TABLE><br>Not so on that car. That module is different. If it was a 1996 or 1997 i will agree with the module being bad.
