1 - 6 of 6 Posts
I'm driving a 2001 v70 t5. It has bilstein b4 and Eibach lowering springs.
Every single time I hit a corner hard enough for the tires to squeal I get ABS and STC light.
Ill turn it on once, and stc goes away. No matter how far I drive the first turn on, the cruise won't work and ABS stays on.
After turning it on a second time, the ABS will go away after driving a mile or two. Cruise still won't work until the 3rd start. This has been consistent for 10+ times of this happening.
Is this a sensor issue? Or just volvo electronics screaming at me?
I also have all of these codes.
https://forums.swedespeed.com/showt...f-codes-anyone-have-insight-to-usual-failures
Thanks for input.
BCM-0011: LF Wheel sensor
Check if left front axle has the bolt, the tone (ABS) ring still has sharp enough teeth, ABS sensor wiring is not torn, etc.
If you need the ABS module rebuilt, Matt will do it for you.
[email protected]
Thanks a lot, didn't expect you of all people to hook me up with a contact
I'll have my indy look at it tomorrow while he's jamming that IPD exhaust onto it.
and I'll make sure to have him look at all of that.
"Do you mean the reluctor ring?"
Yes
1 - 6 of 6 Posts
