So I have abl headlights and was having issues with brightness. When I checked the lights the bulbs were backed out of the holder. I pulled the headlight out to do some other repairs and checked the bulbs and the holder has some pins missing I’m wondering it there’s a way to repair those missing pins?
Check your reflectors too. ABL are notorious for burning up the bowls by this age now and producing very little forward illumination
V70 2010 / 2.5 FT
Hi !
I've got ABL too on my V70 2010 and am too suffering from very low brightness.
I've already replaced the Xenon Bulbs with brand new and even brighter one, but that didn't lead to a brighter headlight at all.
I assume that my reflectors are dirty or damaged.
Headlights are number 3 or 4 now on my list of 100 things to repaid/optimize on that car :rolleyes:
2007 S60, 2.0T
Are you sure there are pins missing? I changed my xenons 2 years ago (car was new to me then) because one bulb was darker than the other. Turned out it was actually not properly mounted.
It took me quite a while to figure out how to do it correctly. I also thought the pins were broken or bent at first (or maybe they actually are?). If I remember correctly you need to rotate the plastic pins to be able to remove / to lock the bulb in place.
131478
