i was looking for information on the valve bodies on these trannies and came across this extensive report written by an engineer i dont know if this ever been posted but it seems like useful info for gear heads in here. or if anything else a good reading for anybody that can understand it.. <p><A HREF="http://www.sonnax.com/tech-articles/PRE-ATRA08-RCW.pdf" TARGET="_blank">http://www.sonnax.com/tech-art...W.pdf</A>
Re: A Report Written On the AW 55/50SN (deerok)
Does not open
Re: A Report Written On the AW 55/50SN (JRL)
thats strange i just clicked on it and it opened for me....
opens fine, you do need adobe acrobat installed though as it is a pdf file
Re: A Report Written On the AW 55/50SN (jstro)
It finally opened.<br>I found this interesting;<br>"Valve body exchange:<br><B>G.M. Equinox valve body has been installed successfully onto Volvo. In order to do so, a wiring</B><br>harness must match SLT Linear connector either positioned up or down.<br>• #2 solenoid is N.O. on G.M. must use Volvo N.C. on #2<br>• Always resurface castings on all valve body areas.<br>• Seal end plugs for C-1 control, B-4 release, B-1 control<br>
Wow. Good find <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Is this the trans in my 2.4t AWD?<p>I get a vibration every once in a while when shifting into Reverse, kinda feels like the e-brake is on...could any one suggest a starting point to inspect the trans?
