I'm having a problem with the upper weatherstrip on the drivers door. The fit has gotten slightly loose on the small mounting tab that is near the mirror which lets the sealing strip fold into the door crack sometimes instead of sealing it like it's supposed to. I'm trying to decide if I should glue it on with weatherstrip cement or just start over with a new upper piece. The strip is still soft & pliable like new, it's just a little loose fitting on the mounting tab. It folds over right below where I put the painters tape in the picture. Thanks for any info.
weatherstrip cement is a cheap way to see if it fixes it, if it doesn't you still have the option of replacing it.
