(2000 V70R)
Our rear glass wiper blade motor will not park properly, it stops wherever it feels like. :facepalm:
Borrowed a good motor, installed it, same thing &*(^*&#$^*#& so if anyone has had this problem and fixed it, the fix would be nice, thanks.
(My guess is there is a relay somewhere, just where would it be)?
Hey, Jim - The intermittent/control relay for the rear wiper/washer is #204.
Looking at the relay panel in the cabin that's mounted on the firewall,
it's the relay in the upper right hand corner. But I don't think that's it.
The relay only sends power to operate the wiper, not the power to park it.
That comes to the wiper on a separate lead whenever the key is on.
There's a four wire plug to the wiper motor - Check it with the key on:
Pin 1: Green/Orange - Wiper On
Should show constant power with the wiper on
or a short pulse to trigger an intermittent wipe.
Pin 2: Yellow/Violet - Wiper Park
Should show power whenever the key is on.
Pin 3: Orange/Black - Ground
Should always show ground.
Pin 4: Empty - No Connection.
If there's no power on the park lead,
I'd go straight to the harness at the hinge.
Good Hunting!
Nothing else on the circuit at all?
Could be the harness in the tailgate is chafing like in a P2...
Jim, time to change part in the signature that says it's still perfect!
my whole perception of reality has changed
