Look at my green car thread on my swap/COP stuff. I took some inspiration from Jared's thread on the COP wiring and removal/etc. It's not to difficult. The engine side of the harness comes out pretty easily, so sourcing a donor shouldn't be terrible. While you're at the yard, grab a couple extra of the ECM/TCM connector block-off plates for the bottom of the ECU box.So I remember in one of Jared’s threads that he removed the excess wiring from the loom that the manual swap doesn’t require. Was thinking I would like to grab a donor harness and start doing that to it. Assuming the harness can easily be removed from the car. I know you can open the ECM box, split the halves of the bottom plate and access the ECM and TCM wiring.
Did you use the N thermostat setup? Or the RN style? I am leaning toward N if possible, as I just put a new OEM thermostat in the car, along with a new OEM Volvo temp sensor. If there’s an advantage to RN, I could probably use the sensor and thermostat in another car…
You could have a new engine and harness ready to go, if are planning to get as much done beforehand as possible. Even a manual NA car might work as a good donor for the engine harness, if you can find a 96-98. You'd have the proper raceway, don't have to remove the auto trans stuff, and really only have to add back wiring for the TCV/BCV.
You do have to splice the NSS stuff (a little GN/RD wire) and I think the reverse light switch. Other than that, all of the auto wiring/plugs can go away.
We wound up using the N thermostat housing on ours.
I think the '04 C70 would have been a return-less fuel system. I kept the N fuel line set-up on her '97 GLT when we did her RN swap. Had to do a little tweaking of the fuel feed and the vac line that runs over the engine (the 97 GLT has the regulator mounted low behind the engine, instead of on the rail). Again a couple pics on her car's build thread.
