A couple more weeks and they would have just fallen off.
They were almost as bad as the ones on my wife's car. Spite was the only thing holding those on.A couple more weeks and they would have just fallen off.
Actually both of them. I have an invoice from December of 2004 when the car was rear ended and the deck lid, bumper cover, bumper support bar, both brackets and taillights were replaced.One of those has been replaced before too
Only saw one sticker but yea.Actually both of them. I have an invoice from December of 2004 when the car was rear ended and the deck lid, bumper cover, bumper support bar, both brackets and taillights were replaced.
And when I got this car, there was a pretty ugly dent in the replacement deck lid, so I replaced the tailgate with one from a V70.
The B5244T5s are hot in the P2R world probably worth more than $750. I would sell both and use net increase in liquidity towards other goodies, like a Quaife.I mean, you have 2 engines in your garage already...
You could use that $750 towards something else, IMO. Like getting some of the VVT delete adapters and just timing the cams and not messing with the VVT.
I swapped a t9 into my old 850r, you can go read that thread but I'm sure there's better ways to do it than I did lolSo, I bought a t9 from an 04 c70. 140ish thousand miles. Complete pulled out engine including accessories, turbo etc. Gonna sell at least one of the 4t5s.
For the initial install, I intend to replace any leaking seals, install all new engine mounts, timing and water pump, PCV, Delrin subframe bushings and reseal the pan.
I’ll also do my manual swap with M56LK and quaife at the same time.
Hoping to use my 98 v70 NA intake with NA TB and 969 disc and DO88 OTE pipe. N accessory bracket and accessories.
The Japanifold and 16T from the T9 should put the turbo outlet in the same place, right? Other research indicates c70 and 850 use the same coolant hoses, so those should line right up?
Questions, for those who have been there before… what PCV setup do I go with? Would it be a hybrid of the 850 and c70 setups? Or will the 850 stuff line up and fit?
Any other sage advice from someone who has been there? Got a swap thread I should read where you’ve gone that route?
Any suggestion on an angle flange downpipe? Should I buy a complete exhaust setup like OBX or IPD?
I may eventually come back and go COP with a bigger turbo etc, but I’m probably gonna make that the next phase. I already have a base tune for 16T and m56. That might be the 2024 stage..
Great info from ChuckTo stay with the distributor you'll need to run a drill bit through the end of the intake cam so you can get the bolt through to attach the rotor mount. 11mm/7/16" should be sufficient. It'll probably toast your drill bit, as it's pretty hard material.
You will also need the P80 front motor mount bracket.
I believe it has the front mount on it as it came direct out of an 04 c70 and I don’t think it’s been removed.I swapped a t9 into my old 850r, you can go read that thread but I'm sure there's better ways to do it than I did lol
There are other options instead of drilling out the cams if OP doesn't want to I think they're documented in Jared's 850R thread. Also, T9 should already have the correct P80 front motor mount bracket. Unless the yard removed it which would be frustrating
So I remember in one of Jared’s threads that he removed the excess wiring from the loom that the manual swap doesn’t require. Was thinking I would like to grab a donor harness and start doing that to it. Assuming the harness can easily be removed from the car. I know you can open the ECM box, split the halves of the bottom plate and access the ECM and TCM wiring.It's been a minute, but if you're using the N intake, your existing 850 PCV stuff should be good. The wife's car is a '97 with an RN motor in it, and we used the N intake and accessories.
If you stay with the N accessories, they all work, with the couple of remembrances. The main AC/Alt bracket winds up missing 1 mounting bolt location. Hasn't been an issue for us. Also, you'll need to clearance the belt cover underneath the N serp tensioner pulley bracket. You'll see what you need to clearance when you try and bolt up the tensioner. Use that and mark as a guide on what to remove. Some folks suggest using the RN stuff, but the N stuff works fine.
While the engine is out of the car, I'd suggest doing the valve seals as well. They really are a pain while the engine is in the car. Especially those on the rear of the engine. Recently did them on my T5 and the wife's car is going to need them soonish.
Also, seeing as you're doing the manual swap, what are your plans for the auto trans wiring? Removing it all, or just abandoning and making the couple of proper splices? If you're removing it, I would also suggest that you rough-in the wiring for the COP install, as it's easier to tuck away when the raceway is out and accessible. Even if you don't want terminate anything, having the 5 wires there for the signals will be helpful in the future. If you do a COP set-up from VAST, pretty sure he provides a wiring harness, but it all runs externally. Mine is tucked away.
We did the dist ignition on the wife's RN swap originally, and did the COP install a couple years later. The wiring for hers is attached along the raceway. It also works, but just not as clean.
Speaking of the raceway, they are different on the transmission end. Not insurmountable, but you'll need to adjust things a bit to keep wiring out of the way.
