Car: 2006 V50 AWD T5 6 spd manual.
Problem: Water leaking into my car from the A/C vents under the driver's and passenger's seats. The floor is soaking wet on both sides. I DO NOT HAVE A SUNROOF. This is the second time this has happened, the first was when the car was under warranty so the dealer fixed it. I will not bring it back to a dealer with no warranty to be raped.
What is plugged up and where is it located? Again, I DO NOT HAVE A SUNROOF!
Any help would be much appreciated!!!
Daniel
Wow, that's weird that it's on both sides. If it's the a/c plug issue, that usually only affects the passenger side...hopefully someone can chime in!
Where does this a/c plug up occur? I have to try something. The first time this happened it was only on the passenger side of the car, this time it is on both, which is very odd.
Thanks,
Daniel
Thank you so much! All the forum searches I did kept sending me to the sunroof issue no matter how I worded it the search query. This will make my trouble shooting a lot easier. But now I'm confused as to why both sides are wet.
Daniel
