Discussion Starter #1
A/C charging Question?
My son's 95 GLT needs a r134a boost. I found the port to charge but the fitting looks to me like the old r12 type. Is this normal? Do I need to install an adapter nipple on the line to make this work? The manual says to just use a R134a kit to charge.<p><br><i>Modified by dwehking at 3:13 PM 12-31-2005</i><BR><BR>
Banned
Re: A/C charging Question? (dwehking)
I have no idea but the odds on are that it will need an evaporator, ($1,000 to $1,300)<br>If this is the first time he's found the A/C to be low it may take a charge for a few weeks but will still leak.<br> Eventually it will only hold for a few days, at most <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0">
Discussion Starter #3
Re: A/C charging Question? (JRL)
I shud have mentioned that the previous owner had the evaporator swapped out in Jan 2000.
Sounds like you're right on schedule for another evaporator.<p>I'd keep feeding it R134a until then.
Discussion Starter #5
Re: A/C charging Question? (sgmlaw)
I got it charged up yesterday with help from a friend with gauges. Will see how long it lasts.
