1 - 20 of 28 Posts
99 5 cylinder head off of a 2.4L turbo engine. Just leveled, machined, valve job and pressure tested. spent 350 getting this head worked on but am getting a 2.3L engine instead.
250 obo plus shipping.
(also have the rest of the engine components if wanted, manifolds, 13t, etc)
Will this head fit my 99 2.3 t5 motor? Will there be a performance difference? Thanks.
Dan
bump
but the head is 2.4L
Heads are identical. Difference in the engines is the bore of the cylinder, and the compression ratio, which is determined by the piston. I've had both heads off, and they are identical, and VIDA confirms that they are exactly the same.
Because it's put together and I dnot wanna take that engine apart
On the engine I bought? 149000 miles new Pcv and timing belt
Discussion Starter · #12 · (Edited)
Not positive on whether OEM valve seals were used. They were about 30 dollars uninstalled. Pressure tested, no cracks. had slight warpage, but was leveled out. they inspected every valve and installed new valve stems. clean packed and ready to go.
Discussion Starter · #14 ·
on the exhaust yes it is
What machine shop in your area did the work?
Send pm with name of shop
I am interested!
Discussion Starter · #17 ·
PM sent...
Discussion Starter · #19 ·
Bumb dity bumb
How much to ship this bad boy to 49009?
1 - 20 of 28 Posts
