I have looked up and down VIDA, VADIS and cannot find a part # for the Fuel Pressure Regulator that is used on the FWD ME7 cars (99and newer, 55-60 PSI spec). The Regulator is right by the fuel filter on these.
If someone has some time or is doing other work on the car, could you maybe take a peek and see if the part # is easily readable?
I am working on a car that has the old MO4.3/4.4 spec regulator fitted to the vehicle, causing low fuel pressure and a fuel trim code.
Thanks!
that is the damper/absorber that is mounted on the fuel rail....
I am looking for the regulator, with 3 fuel lines going to it....should be by the fuel filter.
I am thinking that the regulator comes with the fuel line assembly....
if anyone looks on their vehicle, see if the lines are molded onto the FPR, making removal of the FPR impossible without breaking the line?
Did you find what you're describing in the webstore?
