1 - 6 of 6 Posts
Well i hooked up the code reader an this is what i got. P0448, p0245, p0455, p0414, and p0130 lol that looks like a head ache any help would be appreciated thanks
Discussion Starter · #2 ·
Ok so i found a vac line that was not even connected it ran from the pcv line to the nipple on the air intake tube just before the turbo ill get to it when i get off but i hope it helps with something
Here is where Google is your friend! When you search try, "P0448 volvo v70r" or "1998 volvo v70r P0245".
That said, looks like you have a EVAP issue, probably the J hose, you have a SAS issue, and some issue with your TCV ( I think you mentioned something about your TCV in another post). Now, if you search those codes like I suggested, you'll find some common fixes for them! Good Luck!
check your gas cap, is it clean, looks like it seals? I bet you need a new gas cap for some of the evap stuff, good start at least.
1 - 6 of 6 Posts
