1 - 2 of 2 Posts
I hope someone can give me a definitive answer I have no fuel pressure I dont hear the pump kicking in I changed the relay to no avail someone said it could be the crank sensor but the pump would still come on if the crank sensor was bad or at least that is what I was told.
with that said the car has sat for a while 2 plus years so I want to change the pump anyway but I have found so many different answers to things on the v70R do I need to drop the tank to get to the pump or no? is it just changing the pump or since it is awd and the R do I also need to do something to the driver side baffles etc any help will be appreciated thanks in advance
Does your car have an immobilizer? Have you verified power to the fuel pump fuse?
1 - 2 of 2 Posts
