1 - 6 of 6 Posts
So after searches and searches..Binging and Googled to death..<p>I'm looking into making my own Air intake for the N/A v70<p>I've found the right kit to buy online which will give me all the hardware and tubing i need for pretty darn cheap...<p>i only need the shorter piece that has a small outlet sticking out of it for the secondary air intake hose.A 2 small holes drilled to adapt the 2 little lines going to the top of the stock air box.<p>Am i crazy?........Stupid idea?<p>should be pretty simple<p>***********************************************************<p>After the first test drive i'd say its alot smoother.Seems to take less pedal to make it move...plus it sounds great when you floor it<p><br><IMG SRC="http://i10.photobucket.com/albums/a150/dn9979/PICT0025.jpg" BORDER="0">
Discussion Starter · #2 ·
Re: 98 V70/S70 N/a home made Intake (abdlock)
the next one i make will be a more direct in,Not using the the stock flex hose and removing the entire airbox
Re: (ecbsykes)
You can go to autozone and spend $35 and make one....hot air intake. You still can't beat the OEM Volvo box for flow and temps.<br>I had this in my car for a while but eventually went back to stock.<br><IMG SRC="http://i56.photobucket.com/albums/g186/adamjjohn203/CIMG0329.jpg" BORDER="0">
I'm not having any issue's here in the 90+ weather were having..So..To each their own..I notice a differance thats all it matters
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>abdlock</b> »</i></TD></TR><TR><TD CLASS="quote"> Am i crazy?........Stupid idea?<p>...After the first test drive i'd say its alot smoother.Seems to take less pedal to make it move...plus it sounds great when you floor it<p></TD></TR></TABLE><p>It doesn't <I>look </I>all that bad, but in reality, a few prancing moose stickers probably add the same amount of hp! Stock box & a K&N drop in seem to work well, but if this 'sounds great', more power (so to speak <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> ) to you.<p>Attention: Kia Rio's & mopeds of "milwauki, or": LOOK OUT <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> !<p>
1 - 6 of 6 Posts
