I have a 98 v70 awd and i want to add a aftermarket 6 hole steering wheel. What kind of hub boss do i need and can anyone point me in the right direction. Thank you.
Momo is straightforward, for the most part...
9018 hub (sorry for the blurry pic)
You have to add a bypass for the airbag, of course.
2ohm resistor plugged into the airbag plug. You need to retain the plug, as it has a capacitor in it.
There is no directional cancel with this hub, it's designed for older Volvos, so if you want that feature, you'll need to add pins that will contact the tab on the stalk
cut this off...
