1 - 1 of 1 Posts
This will fit 850s and 98 X70s. Has the 160 MPH speedo and imperial gallon gas gauge. <b>$240 shipped in the US</b>. This is the exact one you will be getting. I will send this to Canada or anywhere else, but shipping will be more.<p>And as far as gauge calibration - You can go to the dealer and they just flash the OBD system to recalibrate your speedo - you just tell them that you have a UK spec cluster and they take care of it for you. Gas gauge levels should be the same, the numbers will just be different. Apparently if you don't want to get it recalibrated, the numbers will be off by about 6MPH.<p>In the interest of full disclosure, the trip reset button is a little tricky - and I haven't plugged it in to see if it works, but it feels like it is off alignment or something. It might be as simple as opening up the cluster and loosening it up. Worst case scenario you can just pull the gauges out of this one and transplant them into your cluster as some on here (gotboost) have done, then you retain your original mileage too. I've adjusted my original asking price down accordingly.<p><IMG SRC="http://i7.photobucket.com/albums/y282/dwbf1/86f8289a.jpg" BORDER="0">
1 - 1 of 1 Posts
