So, the fine technician that installed the oil filter on my'98 T5 decided to over tighten, use Loctite and I think I saw a spot weld for good measure.
So my friends, does Volvo have some magical tool to remove these extra large diameter filters? I have the blue one that I used on my '00 V70R and but its too small and even if it fit, there are no grooves on the outside of the '98 filter to get any grip.
I did find a wrench at the local autoparts store that had three prongs that contracted & tightened as you turn but no good. I was tempted to stick a frickn' screw driver through it and attempt to turn it but my luck it still would have been stuck and then I would have been screwed.
My goal is to swing by the dealership in the morning and have them just pop it off for me, drop in my last quart of oil and off I go. Hopefully!
