1 - 18 of 18 Posts
Did C70 Convertibles come with HPT in 98?
I've got a bunch of new parts staged in my shop,
but before I installl them on my 97 850R,
I'm thinking of swapping cars.
North American spec cars for 1998:
LPT Convertible - Auto Only
HPT Coupe - Manual/Auto
An easy way to distinguish the 98's from the later models is the small Volvo logo located just in front of the doors. European spec 98's and later models have a turn signal light. Also the Volvo badge on the grille is black and silver rather than blue and silver.
so....c70 convertibles got only the LPT?
The auto isn't a problem cuz I've got all the 5spd stuff.
Re: (mune237)
Quote, originally posted by mune237 »
Just for 98.
After 98, both coupe and convertible models came with HPT and LPT engines.
thanks all, I guess I need to research the diffs btw LPT and HPT; and keep my eye open for a C70.
Re: (mune237)
Besides, finding a 98 Conv is really tough. Made less than 500 for the country.
99's far more numerous.
Re: (mune237)
The easiest way to spot the difference is the HPT was 2.3L and the LPT was 2.4. Don't trust that all people will tell you the correct engine size, but it's on the timing cover if you look in there. It'll say B5234T or B5244T. The 23 and 24 are the engine size.
Actually I meant, what are the physical differences btw LPT and HPT other than displacement. Such as bore and stroke, head design, piston/rods/crank design, intake etc, etc, etc. I know it's been discussed before, but I never paid much attention, cuz I have a 2.3L HPT....time to start reading / searching
just displacement
the rest is the same
Re: (BenES)
Quote, originally posted by BenES »
and a higher compression...
that woudl be a given if you have more displacement
Discussion Starter · #15 ·
J: come on, you can lower the compression, while you add displacement.....and vice versa
Re: (C70drvr)
I Thought That The Coupes Were Only HPT?
The Turbos Between The HPT and LPT ARE Different.
Re: (brettborders)
Quote, originally posted by brettborders »
HPT =16t
LPT = 13t
you can just swap from a 13t to a 16t and then get a retune and be golden also add in white or blue injectors to that and there you have the same car with some extra boost
1 - 18 of 18 Posts
