As we found out with the Dual exhaust thread, getting correct part numbers from a Volvo parts department can be difficult. I am creating this thread as our ongoing reference. Maybe I'll add pictures with each item at some pointIf you have a part number and pricing for a S70 or V70 part please post it and I will add it to this growing list. Comments and suggestions are appreciated.
Tire Sizes:
15" Base/GLT: 195/65/15 - XC: 205/65/15 - AWD: 195/65/15
16" - 205/55/16 ( AWD & R )
17" - 215/45/17 -- 225/45/17 slightly rub on the inside fender liner
Part Numbers & estimated pricing:
SUSPENSION, BRAKING & HANDLING
1. Ohlin's Road Handling kit from Volvo for 98-00 AWD V70s:
- 9204201-9 : front shock kit
- 9451817-2 : rear shock kit
For Nivomat equipped vehicle "with lowered chassis."
Front shocks : 9204141-7
Rear Nivomats : 8626025
Front springs : 9481 636-0 kit (springs #3546641 marked with blue spray on a coil.)
Rear springs : 9200184
2. OMP strut tower bar
3. OEM strut brace
- 9204247
4. 302mm brake upgrade
- Caliper brace to adapt from 280mm(11") rotor to 302mm(11 7/8") rotor: 8602456
- 302mm front rotor: 272276
- front pads
- rear pads.
5. FWD Nivomat rear shocks - 8626028-8 - $338.48 each
Suspension Summary (updated October 2011)
discussion thread
Front suspension:
AWD - Front shock - lowered chassis: 9173850
AWD - Front spring - lowered chassis: 3546641
AWD - Front shock - V70R:
AWD - Front spring - V70R:
AWD - Front shock - XC70: 9191569
AWD - Front spring - XC70:
FWD - Front shock - V70 T5: 8600901 (Front spring suspension ( MARKED 39, 49, 59, F3 See product sign for marking. R2, R9, T6, F5, H2, H5, H8 H9, N1, M7, M5, Y4, Y7, M7)
FWD - Front spring - V70 T5: 3546640
Öhlins Front shock kit: 9204201-9
Öhlins Front AWD Spring Kit:9204141-7
Rear suspension:
AWD - Rear Nivomats - lowered chassis: 8626025
AWD - Rear Spring Kit - lowered chassis: 9200184
AWD - Rear Nivomats - V70R: 8626027
AWD - Rear Nivomats - V70 XC: 8626026
FWD - Rear Nivomat - V70: 8626028
Ohlins Rear shock kit: 9451817-2
Öhlins Rear AWD Spring Kit: 9481769-9
APPEARANCE & OTHER:
1. xxxxxxxx-x Rear V70 Spoiler: +/- $180
2. V70 XC grille
- 9190777-4 - 2000 V70 XC - $233 at dealer
- 9178483 - 1998 V70 XC - +/- $193
3. Volvo 6-disc CD Changer
3533937 - CD Changer - +/- $180
9452032 - Cable Kit - +/- $73
9166801 - Mounting Kit - +/- $77
9182729 - Cover - CD ( carpeted piece for V70 rear area, holds changer ) - +/- $171
4. 2003 Volvo C70 headlamp lenses
U.S. part- 9467892 - $250 approx. - requires H11 bulbs
U.S. part- 9467893 - $250 approx.
ECE - 9467889 - euro has a separate DRL - still uses H7 bulbs
ECE - 9467888
5. Dynaudio speaker kit:
S70 Kit: 9452163
V70 Kit: 9452164
S70 individual Dynaudio P/Ns:
Rear tweeters:
9452157
Rear subs:
9452154
Rear door mids:
9452153
Right Front Door mid:
9452152
Left Front Door mid:
9452151
Dash tweeters:
9459035
6. Parts to add Volvo Dolby Pro-Logic to 901 headunit:
Centre speaker 9472027-3
Cable for centre speaker 9456887-0
Screw for speaker (2 pcs) 972081-4
Screw for speaker 980576-3
Nut for speaker 1331699-7
Speaker grille 9198811-3
Dashboard top cover 9422771-7
Screw 976154-5
Screw 966378-2
Dolby Pro Logic processor 3533799-7
Bracket for DPL processor 3533982-9
7. S/V70 auto dimming rear mirror - 9464006 - $42.00 dealer
8. Radio Remote Control
Part #9459783, +/- $90 USD, covers HU-611, 613, 801, 803.
Part #3533715, +/- $150 USD, covers SC-816, 901.
9. Amber rear turn signal bulb - 989842-0
10. 2000 V70R Steering wheel
Color code: 2724 - dark graphite
Part # 8628370
Cost: $300 USD (approximately)
11. 2000 V70R automatic leather shift knob - #8671185
EXHAUST & PERFORMANCE:
1. Volvo Dual Exhaust system for 98-00 AWD V70s:
- 9470703: muffler, R - +/- $276.42
- 8631696 : end pipe - +/- $65.99 each or 9470988 (alternate part, nearly identical)
- 9484490: frame, left with rivets (bumper exhaust trim piece) - $9.61
- 9169283: rim/frame, right press in, no rivets (bumper exhaust trim piece)
- plastic rivets
2. 100mm Stainless Steel Big Bore Exhaust Tip from IPD, IPD Part Number: DC2105- +/- $65.00 ea.
3. K&N air filter, #xxxxxx - +/- $65?
4. Exhaust manifold studs
MISC
Turbos:
15G - B5234T 225hp/B5234T5 240hp 1994-1995, conic outlet
15G - B5234T 225hp/B5234T5 240hp 1996, straight outlet form turbine.
16T - B5234T4 250hp 1996 | 850R man, straight outlet from turbine
16T - B5234T3 240hp 1997-1998 | S/V/C70 T5, straight oulet from turbine.
16T - B5234T3 240hp 1999-2000 | S/V/C70 T5, angled outlet from turbine.
16T - B5234T3 250hp 2001- S60/V70N T5, angled outlet from turbine.
18T - B5234T4 250hp 1997-1998 only S/V70R man FWD/AWD, 275/60 wastegate and straight outlet form turbine.
18T - B5234RT 250hp 1999 only V70R AWD, 4-vxl aut, 300/70 wastegate and angled outlet form turbine.
Exhaust Manifold Related
948645 – flange nut – QTY 10 - (exhaust manifold nuts)
982667 – control rod – QTY 10 – (exhaust manifold studs)
Tire Sizes:
3. OEM strut brace
- 9204247
- front pads
- rear pads.
discussion thread
Front suspension:
Rear suspension:
APPEARANCE & OTHER:
2. V70 XC grille
ECE - 9467888
S70 Kit: 9452163
V70 Kit: 9452164
Rear tweeters:
9452157
Rear subs:
9452154
Rear door mids:
9452153
9452152
9452151
Dash tweeters:
9459035
Screw 976154-5
Screw 966378-2
Part # 8628370
- plastic rivets
MISC
Turbos:
