So I got the car about a month ago and im loving every second of it but there's one problem.... My speedometer goes in and out. The previous owner said it starter when he installed the boost gauge but idk if that's true. Has this happened to anyone else? If so how did you fix it? It's also a problem because no Speedo = no odometer either. Thanks in advance and have a great day
Is there an ABS light on? I have seen problems with the odometer/speedo with a faulty module and or sensor...
ignition switch would be my guess. relatively cheap and easy to replace. That fixed my speedo issue on my 850R.
+1 it's the abs module and +1 for midwest-abs. You won't have to deal with again.
