1 - 2 of 2 Posts
I have a 1995 850 turbo sedan. In the past month, we replaced both CV axles, both front discs, and all front pads. There was no real reason to replace the front brakes except for a good amount of squeal, and the rotors had a bad ridge in them.
Before the replacement, both front brakes were fine. Now, the right side has little, if no effect. When driving, it feels somewhat like a warped rotor, but the rotor definitely isn't
What could have changed during the brake job? The old rotors already hit the garbage dump, so I can't go back and check.
Thanks
Joe
Did you grease the slider pins? If one of those gets jammed up it'll cause those kinds of problems. I had it happen to me a year ago or so.
1 - 2 of 2 Posts
