Euro RICA Ecu for 96-97 850 turbo/T5/R's.
tuned for:
- 18psi
- 3'' turboback exhaust
- rear 02 delete
- no egr
It is a euro ecu so the tune is more aggressive, however to smog the car you will just have to switch out the ecu for a stock one because the obII port only works with the volvo scan tool.
http://www.vivaperformance.com/products/1998-V70-Software-Upgrades.html
SOLD
title says 95-97, description says 96-97? I would really like to run this on my 95 T5R, but it needs to be a 4.3 ecu. Also, were you running this with a MBC or stock TCV?
Ran this with a stock BCV (slightly different then a TCV and needed for 4.3)
It will work on 95-97 because it has no EGR. If it had EGR then it would be 95 only, but if you install this on a 95 it will just ignore the EGR components so it will work perfect, but is technically for 96-97 because they did not have EGR.
