1 - 2 of 2 Posts
Discussion Starter #1
Hi,<p>My dad recently bought a good condition 1992 940 Turbo. While doing a tune up, the mechanic working on the car saw that the fuel filter and a fitting had to be changed. Parts were ordered and the job was "done". <p>Time comes to start the car and gas starts leaking from the fuel lines. Turns out that the WHOLE LINES need to be replaced- front to back.<p>I placed an order at Volvo and "part discontinued" Is there some way to get this job done without manually fitting a steel line and bending it or am I in a tight spot?<p>Any help/constructive comment would be appreciated.<p>Thank you.
Re: 940Turbo Gas Line replacement help (MisterDeeds)
Visit a busy machine/hose/hydraulic shop with your old fittings in hand and they should be able to put together new flexible lines with new end fittings to match the connections on the car.<p>George Dill<p>
1 - 2 of 2 Posts
