1 - 2 of 2 Posts
I have a 960 with a blown engine and a 940 with a wiped out front end.
So the question is...
Can I take the engine from my 940 wagon and drop it into the 960 body?
The 960 has a new tranny and I'd like to use that one if I can.
Re: 940 to 960 Engine Swap (AlpineDog)
Yes, it would be possible to swap the engine but ...
What years are the cars?
Is the 940 a turbo? The battery maybe on the wrong side, but could be moved.
I'm assuming the 960 has the straight six, if so no you cannot use the trans, you'll have to use the 940 one.
The under hood wiring harness may have to be swapped.
1 - 2 of 2 Posts
