Discussion Starter #1
I'm researching the Volvo '94/'95 850 estate BTCC. Does anyone have the specs on this car? I'm looking for: weight, wheel/tire size, torque, bhp, gear ratios, final drive ratio. <p>thanks,<br>Glen
Re: '94/'95 Volvo 850 estate BTCC specs question (xlt)
I can give you some info, i.e <p>1984cc 5 cyl engine developing 280+ bhp, 6 speed sequential gearbox, 8 pot disk brakes and used to race with a catylitic conveter fitted !!!.
check the third post down from the top of this forum.<br>that subject might help?
Discussion Starter #4
Re: (jrodT5)
Sorry, I don't see any BTCC-related specs in the "800 Series Model Information" thread.
Discussion Starter #5
Re: '94/'95 Volvo 850 estate BTCC specs question (cocka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>cocka</b> »</i></TD></TR><TR><TD CLASS="quote">I can give you some info, i.e <p>1984cc 5 cyl engine developing 280+ bhp, 6 speed sequential gearbox, 8 pot disk brakes and used to race with a catylitic conveter fitted !!!.</TD></TR></TABLE><p>Thanks, I just found an old Volvo press release with the following info:<p>Chassis: Four door shell stiffened by additional tubular steel roll <br>cage. <p>Engine: Highly tuned 2 litre unit:- <br>Number of cylinders: 5 <br>Valves per cylinder: 4 <br>Displacement mm: 1,999 <br>Stroke mm: 73.9 <br>Bore mm: 83 <br>Max. output KW/bhp/rpm 205+/280+/8500 <p>Catalytic Converter: Catalytic exhaust emission control and silencer fitted. <br>First BTCC car to do so before mandatory in 1995. <p>Transmission: Purpose built racing transmission. Six-speed sequential - <br>push for low gears, pull for high gears. Interchangeable <br>ratios. <B>(can anyone estimate what these ratios probably were?)</B><p>Suspension: McPherson struts at front. Coilspring over damper - Volvo <br>Delta link at rear. <p>Braking system: Brembo calipers and discs. <p>Cooling: High efficiency aluminium water radiator. Heat exchanger <br>for engine and transmission oil. <p>Steering: Modified Volvo rack and pinion. Momo steering wheel. <p>Wheels and Tyres: Dunlop racing slicks - 6 allowed per race, Dunlop wets <br>and intermediates -16 allowed per event. Mounted on OZ <br>forged magnesium alloy racing wheels 18" diameter x 8.2" <br>rim. <p>Additional Features: Heated windscreen
Re: (xlt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>xlt</b> »</i></TD></TR><TR><TD CLASS="quote">I'm also still looking for:<br>weight<br>torque</TD></TR></TABLE><p>I think the weight was 2150 according the regulations but this has changed a few times over the years. <p>The early engine's developed 280+ bhp, the later ones close to 300. Torque was different per track. As far as I'm informed different exhaust manifolds were used and the velocity stacks of the 5 individual throttle bodies could be exchanged for different length ones to suit the torque to a specific track. Same goed for the gearbox. Different ratio's per track.<p>These cars did not use 8 pod calipers. The estate was the least technical version, the later sedan's were much more advanced.<p>Engine was placed against the firewall and on a sandwich carbon alloy "subframe" plate. With the dry sump oil system the engine was placed straight on this plate and was mounted a lot lower in the car. The X-trac 6 speed sequential gearbox was situated in such a way that the driveshaft ran in front of the engine instead of the back with the production 850's. Car's were right hand drive btw.<p> <IMG SRC="http://www.swededemon.com/images/Albums/BTCC850/BTCC850-Images/8.jpg" BORDER="0">
