Your problem really sounds like you blew a hole in a pressure hose like I did. Look at each hose and feel around for bubbles and holes. Check all clamps and connections as well. Also, check the rubber collar connecting the turbo to the output pipe (aluminum pipe going over the motor.) Look at these first and then let us know what's up. Good luck!
Prospero
Prospero
