1 - 20 of 26 Posts
Discussion Starter #1
So I was wondering if it is true that 93 octane will give you more horsepower in a T5 along with Octane booster..... My friend said it could give me 30hp but I DOUBT that....?
Re: 93 octane with Octane Booster (cicatrizdare)
in oregon we only have 92.... <IMG NAME="icon" SRC="http://********************/smile/emthdown.gif" BORDER="0">
Discussion Starter #4
Re: 93 octane with Octane Booster (primodevil)
But does it make a difference in performance like 87-93...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>primodevil</b> »</i></TD></TR><TR><TD CLASS="quote">in oregon we only have 92.... <IMG NAME="icon" SRC="http://********************/smile/emthdown.gif" BORDER="0"> </TD></TR></TABLE><p>The laugh is on us because CA's highest is 91 !!<p>My T5 runs fine, as far as I know. <p>I heard the Californian Mazda crowd has a bit more trouble with its turbo 2.3L because it was designed to run on 93... not 92 nor 91.
Re: 93 octane with Octane Booster (genjy)
Yah, higher boost, bit higher compression motor I believe. Thats what ya get for pushin a 4 banger that hard <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Re: 93 octane with Octane Booster (S40T5Lover)
I run 94 whenever I can, otherwise 93. Honestly , I don't notice a difference between the 2 , however ...if I were to jump down to 87, I'm sure the BSR would cry and my car wouldn't run that great. Don't think you'd need an octane Booster with 93 , but what do I know, I can't even feel the difference between 93 and 94
I tried a gallon of Xylene to get my octane to about 94.5. The car felt more responsive but hard to tell if I gained any HP.
Re: (volvoNB)
hey, VolvoNB .. yer right looks tight (still mad at [email protected], but understand she was only doing her job <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> ) have you concidered adding that Volvo slash to that grill? that's what i'd do , but looks nice just the same <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: (V50_T5)
I've been putting about 5-6 gallons of 100 octane unleaded in my R and filling the rest of the way with 93.
Re: (volvosince16)
mixing race fuel and 93 is much much better the octane booster and 93.. even with race fuel on our current mods you won't see much.... Now if have a 400+ HP VTEC 1.8 you will see say 50 HP if the boost is turned up..
Re: (V50_T5)
Thanks V50_T5! My car is all outside appearance. The inside isn't so pretty not like your engine bay. I don't think I should put the slash back. My car is debadged in the back. Right now, I'm debating about MS Design front lip. I would also like the carbon fiber side mirror caps too. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> <p>Edit:<br>Oops, forgot about the rims. I'm surprised they are holding up this well. It's been 2 years and no noticeable bends. I've a few scary pot holes too. I'm surprised because the rims weigh 16lbs each. One rim did get a leak on the inside with no visible damage. Had to go through a lot of emails and calls to get it replaced. Other than that I'm happy.<BR><BR>
<i>Modified by volvoNB at 9:01 AM 9-23-2008</i>
Re: (Oldman)
<IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Oldman</b> »</i></TD></TR><TR><TD CLASS="quote">mixing race fuel and 93 is much much better the octane booster and 93.. even with race fuel on our current mods you won't see much.... Now if have a 400+ HP VTEC 1.8 you will see say 50 HP if the boost is turned up..</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Oldman</b> »</i></TD></TR><TR><TD CLASS="quote">mixing race fuel and 93 is much much better the octane booster and 93.. even with race fuel on our current mods you won't see much.... Now if have a 400+ HP VTEC 1.8 you will see say 50 HP if the boost is turned up..</TD></TR></TABLE>
Re: (Oldman) (volvosince16)
point being a high strung small engine with lots of boost and the ability to increase boost can make use of a mix of race fuel and 93 octane. A max mod S40 with octane booster and 93 IMO you will see next to nothing.
Re: (Oldman) (Oldman)
I've got quite a bit of boost <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> I started using it in the heat to hoping to help prevent timing pull <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>volvosince16</b> »</i></TD></TR><TR><TD CLASS="quote">I've got quite a bit of boost <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0"> I started using it in the heat to hoping to help prevent timing pull <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0"> </TD></TR></TABLE><p>not on a s40....
Running 91 doesn't seem to be a problem for me... I would never run anything less, but paying upwards of 4.90 a gallon then driving to the nearest auto parts store to pay another 3 or 4 for the octane booster just doesn't seem worth it to burn it away going 6 MPH on the 405 <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Re: (shadowlord)
in general E85 has less energy so I would expect HP to be less... now if you inject water / alcy from a snow injection system....
1 - 20 of 26 Posts
