My kick down cable started sticking about a week ago to the point where it will come out and have a lot of slack and then it will not go back in (or recoil so to speak unless I feed it back in with my fingers.). What happens is that the accelerator gets stuck or really stiff and/or the transmission shifts erratically or not at all until I push the cable back in. I have tried adjusting the two nuts that the cable feeds through to change the cable's positioning. This has not helped. I have also searched for a previous thread on the forums that may address whether the cable can simply be lubricated or if it needs to be replaced altogether and what that would entail. I have not found anything that has really helped yet. Has anyone been through this and what would you advise?
Thank you,
Justin
Thank you,
Justin
Should be some answers in this mess...
http://www.google.com/search?hl=en&...=any&safe=images&tbs=&as_filetype=&as_rights=
George Dill
Also try the link to K-Jet that I posted on your other thread.
I just had this exact same problem. The cable had rusted and started sticking I had to replace the cable which means dropping the transmission pan. If that's you only car a temporary solution is to disconnect the cable at the top and use the gear selector inside to do your own shifting just be careful not to slide it into reverse.
Thank you. I ended up taking it to a friend of mine and I believe all it needed was a little lubrication. So far, so good.
